my old cg is doing my head in
liam
#1 Unread post by liam »
ive got an old cg 125 and it wont run proply it ticks over struggles to rev up and dusnt rlike going wen i put it in gear can any1 help please ive cleand the carb changed the plug changed the air replaced all top end gasket cleand and checkd all wires eg earths ect and now i feel like im at a dead end could it b any of the electrical components? :frusty: :frusty: :frusty: :frusty:
#2 Unread post by BuzZz »
sounds like its prbly carb probs frum wat i can make out frum ur post but i cant reely say fer sure and i can't reely say i understood alot of it it helps to be specific and use somewat standardized english to get taht info across so those reading it can figure out waht the hell yer talkin about
Just a suggestion though.... :mrgreen:
#3 Unread post by Sev »
What are your valves set at?
What's your float height?
What is the idle set at?
Did you check the fuel filter?
liam
#4 Unread post by liam »
hi all thanks for the help the wudwuf key had gone it was sparking at tdc
