xornr89 wrote:Shorts wrote:xornr89 wrote:Shorts wrote:Honda VTR250 (I ride this one)
Honda CBR250R or RR
Honda Hornet 250
Suzuki Bandit 250
Yamaha TW200
Yamaha Zeal 250
THanks for the list, i will look in to it! Thanks again!
No problem. As DivideOverflow noted I did keep 2 strokes off the list. The reason behind that is a first bike should be cheap and easy to maintain so that riding and reliability can remain a top function as opposed to working on it. Disclaimer: I am NOT saying 2 strokes are
difficult to maintain. I am NOT saying 2 strokes are unreliable. Rather am taking the 2 stroke maintenance out of the equation for the first bike. With a 4 stroke, regular maintenance items must be up kept so one is not losing the benefit of 'learning to work on' their first bike.
It's simply, keeping it simple this first go 'round.
Thanks again! Sorry i am not familiar with the term Strokes (I have posted about STROKES before), So the lower the strokes the better, faster, easier to maintain? Can you please help me understand this stroke thingo? By the way not the medical Stroke... I know what that is...
LOL
When referring to engines, the number of strokes are the number of cycles an engine goes through to make power. Two-stroke engines fire once every revolution, while four-stroke engines fire once every other revolution. This gives two-stroke engines a significant power boost.
Disadvantages:
Two-stroke engines don't last nearly as long as four-stroke engines. The lack of a dedicated lubrication system means that the parts of a two-stroke engine wear a lot faster. (You have to mix the oil in with the gas, unlike a 4 stroke).
Two-stroke oil is expensive, and you need about 4 ounces of it per gallon of gas. You would burn about a gallon of oil every 1,000 miles if you used a two-stroke engine in a car.
Two-stroke engines do not use fuel efficiently, so you would get fewer miles per gallon.
Two-stroke engines produce a lot of pollution -- so much, in fact, that it is likely that you won't see them around too much longer.
The pollution comes from two sources. The first is the combustion of the oil. The oil makes all two-stroke engines smoky to some extent, and a badly worn two-stroke engine can emit huge clouds of oily smoke.
For motorcycles, two-strokes also have a very small powerband. They only make power within a small RPM range. So you would be accelerating, and all of a sudden (once you hit that RPM range) the bike would surge violently in power, perhaps taking you by surprise if you aren't expecting it.
Two-strokes are good for race bikes, not beginner bikes.
