ignition lock stuck
ignition lock stuck
i bought a 1989 katana 750...(cheap and close) but i thought it was smart to lock it up so nobody can roll it away. so ive tryed alot to get it unlocked, anyobdy have any tricks that might work?
- coffee_brake
- Legendary 300
Do you mean the steering lock?
You should be able to push the key in while moving the bars a little until the key turns, if you mean the steering lock. You have to move the bars while gently turning the key to find the exact spot where the key will turn.
Good luck...
Good luck...
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Many fork locks don't get used often so they build up corrosion and dirt. So they are hard to unlock. Shoot some WD-40 (or your favorite alternative) into the ignition switch and on the locking mechanism itself. The lock mech. will be under the top triple clamp and will be some sort of lever, pawl or shaft that engages a tab welded to the head tube of the frame.
Then try the wiggle-and-unlock thing again.
No Witnesses....
- Legendary 1000
What Buzzz said. Except that on some bikes the lock is on the frame and ingages the neck bolt or tree internally to lock. (some newer bikes use a solenoid to engage lock rather than a key) If you cannot get loose there are two alternatives drill and remove tumblers and replace yourself (if replacement tumblers are available) Take to lock smith.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
