How often do you change the oil.
I thought every 3000 miles. like a car. My rider friend says every 10000 to 15000 miles. Also, if I change it myself, do I have to use motorcycle oil or can I use regular car oil?
I bought 3 quarts of motorcycle oil for my GZ250 and a filter, and the total was $35. I can get it done for me for $50.
For my vulcan the manuel says every 6,000 miles.
And it calls for SAE 10W40 or 10W50 cold weather
And SAE 20W40 or 20W50 for warm weather.
As for miles I usually go 1,500 to 2,000. And use the 20W50 year round.
BTW I use castrol gtx.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
one seater
horn relocation
- Skier
There's plenty of threads about this. Check the search function.
I don't like faking it, so I get my oil analyzed at every oil change. It's the only way to be truly sure how your oil is doing.
- Real Name: Ryan
Only true in a way... If you use car oil with a detergent it'll let it foam up easier, and also because of the modern anti-friction additives, it can make your clutch plates slip. The anti-friction additive gets into the friction material and even after you change your oil again it'll make your clutch slip.Skier wrote:Not true.Gadjet wrote:Do not use car oil in your bike - you'll wreck your clutch
Oh, and about your friend's 10-15K mi between changes...
Oil
The guy that changes his oil every 10-15 K Mi. must change his bikes every year. That will kill an engine. My oil gets changed at 3000 Klm.- 1800 Mi. Had a 750 Honda for 6 years,never took oil. Used synthetic oil in my Yamaha 1100 once , clutch slipped like h#&*. Ok when i went back to Bike Oil.
Ride careful, you'r dead a long time .
- jimyed
Could you expand on that? Everything I've raed suggests that the friction modifiers in modern car oils are bad for bike clutchs (Ok may not wreck them but are not good).Skier wrote:Not true.Gadjet wrote:Do not use car oil in your bike - you'll wreck your clutch
I change my oils every 5000KM or so. I use Semi Synthetic Motorcycle oil.
I change the Filter every time. And i do it myself.
“Motorcycle racing should be the domain of hairy men with death wishes that perform magical displays of ballet with fire-breathing beasts hell-bent on killing them at the first opportunity."
- Franz
- Franz
