bzippi wrote:I have a question on this topic that I'm hoping some of the more experienced riders here can help with.
I agree that the front brake has the greatest stopping potential. But as you use your front brake and the braking causes weight transfer from the rear to the front of the bike, does this increase the potential of locking the rear wheel ... either by aggressive use of the rear brake or using the engine's stopping power?
Thanks
Correct, weight transfer means as braking occurs you get less and less traction available for the rear tire. This is why safety courses teach "light to lighter" on the rear brake: apply it and as you continue to brake, ease off.
shane-o wrote:Skier wrote:When you are braking when the bike is upright, a locked rear tire will
not cause you to go down. Last time I checked, the MSF as well as other rider training programs in the States tell riders to keep a rear wheel locked until stopped. They do mention you can release the rear wheel when it is perfectly aligned but keeping it locked is an option.
Just a few years ago, the state program I currently am an instructor for, had rear-wheel skids as an exercise. That's right, newbie riders were locking the rear wheel when coming to a stop and
nobody fell in my class.
I will stand by my statement of
a locked rear wheel provides more braking force than a rear wheel without braking forces applied. If you don't believe me, accelerate your bike on a flat stretch of road to about 15 MPH. Pull the clutch in and don't touch either brake. It will take you a long time to stop. Now, go to 15 MPH again and stand on the rear brake. The rear tire will fishtail a bit but will follow the front wheel and you'll come to a stop.
Perform the above at your own risk or do some reading and research into it.
Well mate, no disrespect to you this is not personal, BUT,
I'm shocked !!!!!
I dont know what to say to that.
Maybe we should just agree that we have differing opinions on this matter, and thats ok, cause if we were all the same it would be a boring place.
Peace
It can be a matter of fact if you try my example. A motorcycle stopping only by friction between the wheel bearings and powertrain, no brakes or engine braking, has about zero stopping power. A locked rear wheel provides magnitudes of power more braking force. Not much to it.
(edit)
Here is an excerpt from my state's motorcycle riding manual:
Notice it has the section about keeping the rear tire locked. It also states you can control the bike with a locked rear tire.
Look at the diagram: See how using both brakes stops the quickest? If you were to apply maximum braking on the front tire and instantly lock the rear tire, you will still
stop faster than just using the front brake. The small amount of braking force given by the rear tire is better than
no braking force.
