tire question
- HYPERR
- Legendary 3000
Spoked rims require a tube. Really the only bikes that have spoked rims these days are dirtbikes(for obvious reason) and cruisers(for looks). BMW's spoked wheel has a patented technology that does not require a tube.
- jonnythan
Yup.HYPERR wrote:Spoked rims require a tube. Really the only bikes that have spoked rims these days are dirtbikes(for obvious reason) and cruisers(for looks). BMW's spoked wheel has a patented technology that does not require a tube.
And those cruisers generally use the same tire whether the rim is spoked or not. Wonder how they do that..
- HYPERR
- Legendary 3000
Very good point.jonnythan wrote:Yup.HYPERR wrote:Spoked rims require a tube. Really the only bikes that have spoked rims these days are dirtbikes(for obvious reason) and cruisers(for looks). BMW's spoked wheel has a patented technology that does not require a tube.
- gsJack
- Legendary 500
- Years Riding: 30
- My Motorcycle: 02 GS500
If that's a tubeless tire on a cast rim made for tubeless tires I'd just plug it on the bike and used it up and have done so a few times unless the nail is within about an inch of the edge and might not plug safely.
As far as putting a tube in the tire here is what Metz says:
Is it possible to fit a tube into a tubeless tyre?
Herewith we certificate that METZELER tubeless tires can be used with tubes on the admissible standardized rims. The allowable top speed is 130,43 mph for the "H"- tires and 142,86 mph for the "V"- and "Z"- tires You are bound to use the same product concerning the tubes and the tires on your motorcycle.
Meaning that METZELER-tires have to be used with suitable METZELER-tubes. Existing regulations of the motorcycle manufacturers have to be observed.
I plugged one like new rear Dunlop touring tire and used it another 20k miles before I traded the bike in with quite a bit of tread left on it. I wouldn't run a plugged tire on a mc unless I plugged it myself.
I mix a lot of tires and have rarely had a problem with it but I use my own judgement on what I'll mix. Here's the tires I've run on my last two bikes, a couple GS500's:
http://img.photobucket.com/albums/v443/ ... irelog.jpg
407,211 miles in 30.1 years for 13,528 miles/year average. Started 7/21/84, updated 8/26/14
