I have an idea
- Flipper
- Real Name: Nancy
- Years Riding: 7
- My Motorcycle: 2010 Ninja 250
I have an idea
I got stuck at a left arrow turn signal again because my bike wouldn't trip the loop.
I had to wait two rotations before a car came up behind me and tripped it.
Last year I bought one of those green light magnets that you stick under your bike that's suppose to trip the signal.
It has never worked.
Since it's still stuck on my bike.
I was thinking I could pry it off and glue it to the outside edge of my boot.
That way I gould set my foot down right on top of the line where the wire runs.
Do you think this could work? I already have the magnet.
Any ideas on how I could attach it to my boot?
2010 Ninja 250
2006 CB600F (sold)
2006 Honda Rebel (sold)
2006 CB600F (sold)
- Skier
It doesn't matter how close the magnet is, it isn't doing anything for the sensor. If your large mass of motorcycle isn't tripping the light, a tiny amount of metal closer to the sensor isn't going to do much.
From Dan's Data.Passing a magnet over an induction loop will induce a little current in it, but it won't change the loop's actual inductance any more than a similar-sized lump of unmagnetised metal with the same conductivity would. It's change in inductance that causes the vehicle detector to trigger...
- dr_bar
- Real Name: Doug
- Years Riding: 44
More than likely, you'd trip the sensor with just the kickstand...TrueFaith wrote:I have my Green Light Trigger zip-tied to my kickstand. If it doesn't initially trip the light, I shift into neutral and put down the kickstand momentarily over the sensor. The closer proximity to the sensor of the trigger and kickstand metal usually does the trick and will trip stubborn lights.
- Skier
Enough marketing and I'm certain the squids around here would buy that up.jonnythan wrote:I'm not sure I'd like my foot constantly stuck against the side of my bike because of a magnet
"Worried about falling off your bike in THE TWISTIES? Stuntin' but keep falling off? Buy a new SandalMag-3000, guaranteed to keep you on your bike!"
- Brackstone
- Legendary 1500
- Real Name: David
- Years Riding: 3
- My Motorcycle: 2010/Ducati/Monster 1100
The new SandalMag-3000 will hold you to your bike even when it falls over!Skier wrote: "Worried about falling off your bike in THE TWISTIES? Stuntin' but keep falling off? Buy a new SandalMag-3000, guaranteed to keep you on your bike!"
Aprilia Shiver 750 (sold)
- flynrider
- Years Riding: 30
Yep. That method works for me without any gadget attached to the kickstand.dr_bar wrote:More than likely, you'd trip the sensor with just the kickstand...TrueFaith wrote:I have my Green Light Trigger zip-tied to my kickstand. If it doesn't initially trip the light, I shift into neutral and put down the kickstand momentarily over the sensor. The closer proximity to the sensor of the trigger and kickstand metal usually does the trick and will trip stubborn lights.
Bikin' John
'93 Honda CB750 Nighthawk
