Hi there
Have a strange problem guys, I hope someone can help.
When pull off and what the most power the bike feels like it jumps out of gear @ 8000 rpm but shut off the throttle and it goes fine with no problems but will not go higher than 8000 rpm, is it clutch related? or gearbox related? what will it do to my engine if i leave it like this?
Engine has new bearings fitted and I don't want to damage anything again.
Regards
Ozaki
zzr1100c strange problem
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
Adrenaline ?
dot 2 dot @ 300 K +
New chain and sprockets
checked all the final drive, no problem here
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
Adrenaline ?
dot 2 dot @ 300 K +
sprockets look fine, chain looks fine too
Adrenaline Junkie
Adrenaline ?
dot 2 dot @ 300 K +
Adrenaline ?
dot 2 dot @ 300 K +
- Real Name: Ryan
I'd vote to check your timing. I've heard of that happening when people have put in new cam chain tensioners without retracting them first... Is it very responsive below the 8k?
Does the engine rev above 8k when not in gear?
