ENGINE MAKING A WOOPING SOUND
bluedragonbrown
#1 Unread post by bluedragonbrown »
Hello
I have A 78 HONDA CB400T. When the engine is runing there is what sounds like woop woop woop on the left side. Speeds up when engine rpm's go up. I only heared it after taking off the mufflers. I just got the bike is not runing right. It will idle ok when I try to rev it rpm's start to go up then drop right off let off the gas and will back fire through the exhaust. :frusty:
#2 Unread post by Johnj »
First off put the mufflers back on the bike. It was designed to run with the back pressure, and removing the mufflers could lean the mixture up enough to burn a hole in a piston. And that my friend is bad mojo.
fireguzzi
Real Name: Trevor
#3 Unread post by fireguzzi »
Johnj wrote:First off put the mufflers back on the bike. It was designed to run with the back pressure, and removing the mufflers could lean the mixture up enough to burn a hole in a piston. And that my friend is bad mojo.
Yup.
