fork lock
japac1
fork lock
#1 Unread post by japac1 »
When I lock the front fork on my Virago 250, the handlebars remain turned to the right. Is this correct? It seems that the bike is off balance with the bars turned to the right.
jstark47
#2 Unread post by jstark47 »
It does seem odd. All our bikes, the fork lock engages with the bars all the way to the left (same side as the sidestand).
king robb
#3 Unread post by king robb »
it will prolly turn either or...try it to the left....with it to the right it would be terribly out of blance unless the kickstand is on the right too.
2 wheels on the ground
HYPERR
#4 Unread post by HYPERR »
You can turn it and lock it either way.
jonnythan
#5 Unread post by jonnythan »
It's an oddity with the Virago.
Unless the 250 is different from the 535, it'll only lock turned to the right.
edit: Just checked the manual and that is correct. Steering lock only works when the forks are turned right.
Those giving different advice may want to make sure they know what they're talking about in the future ;)
king robb
#6 Unread post by king robb »
jonnythan wrote:It's an oddity with the Virago.
Some of us say prolly and try for a reason :wink:
jonnythan
#7 Unread post by jonnythan »
king robb wrote:Some of us say prolly and try for a reason :wink:
Indeed, can't fault anyone for that.
Others, on the other hand.... 8)
HYPERR
#8 Unread post by HYPERR »
:oops:
RocketGirl
Real Name: Belynn
My Motorcycle: 2007 Yamaha Virago 250
#9 Unread post by RocketGirl »
It IS off-balanced. The last time I used it, I had ridden my Yamaha 250cc to a family gathering and parked in a rental community. Well, we had a HUGE thunderstorm roll by that afternoon. Winds so strong that we packed up the patio furniture and brought them indoors. Hours later I came out to find my bike laying on it's side fortunately on the turf next to the shallow street curb. :shock:
I'll never use that fork lock again.
Amdonim
Real Name: AJ
My Motorcycle: 2000 ZG1000
#10 Unread post by Amdonim »
Fork locks are usually pretty easily broken with enough force, so if it's a choice between locking it, or having it parked with stability, I'd say just leave it unlocked.
