Sand them off!? You're joking right? Yes it helps - by giving me a baseline to better judge your responses to other posts.shane-o wrote:Stickers on the faring I would use a hairdryer thats how I have done all mine in the past, but do not heat the surface to the point of melting :)
As for the tank, most branding is done under layers of clear coat, so, only way to get them off is to sand off then a respray.
hope that helps
Well apologies to Shane-O then. Mine's not under the clear-coat in any case though, it had a thin, clear plastic layer which peeled right off and has left me pick, pick, picking at the rest of it in vain.Wrider wrote:Nope, he's serious. Most of the tank decals saying the manufacturer are applied right after the paint and before the clear-coat.
indiGO wrote:Sand them off!? You're joking right? Yes it helps - by giving me a baseline to better judge your responses to other posts.shane-o wrote:Stickers on the faring I would use a hairdryer thats how I have done all mine in the past, but do not heat the surface to the point of melting
hope that helps
Will WD40 hurt the paint on the tank? I don't mean will it hurt it in a relative sense when compared to sanding, but more in an absolute sense wherein people who are concerned about the appearance of their bike wouldn't typically recommend it.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
