Misadventures in wrenching and riding
- Skier
Might as well repost this here.
My 599 found a friend!
An '06 Triumph Scrambler followed me home across the state today. It looked so happy to be with me I couldn't turn it away.
I've put almost a thousand miles on it, great bike. Love the torque of a big parallel twin and it's far more composed in gravel than my 599.
Cornering on pavement leaves something to be desired with the Scrambler but hey, pavement merely takes you to the next dirt road.
- Skier
Working well so far, but there's a few things I want to fix in a hurry. The front suspension is incredibly harsh on-road and the seat is hilariously uncomfortable compared to my 599. Both appear to be easily fixed.mgdavis wrote:How's the Triumph working out? The Scrambler would be on my short list if I were bike shopping right now.
Speaking of my 599, I was replacing the clutch and inspecting parts when I notice this:
That's my.... (looks up the manual) clutch lifter arm shaft. I am pretty sure that's not normal wear.
The clutch basket is showing its miles, too:
Gonna have to replace the shaft if nothing else.
Strangely all the clutch discs are in spec for thickness but the clutch has been acting wonky lately, so I may as well replace 'em all!
It looks like your clutch basket has some significant fatigue cracks forming.
How many miles are on the 599? It might be getting toward time to replace the whole assembly, before your clutch grenades!
Caveat - I'm no motorcycle mechanic, but I have a feeling for when things look "not right".
It's too bad our motorcycle shop manuals aren't written like aircraft tech data. If they were, you could just find the inspection criteria in the appropriate T.O. and it would tell you the acceptable limits.
'07 Suzuki V-Strom DL650
Molon Labe!!!
Molon Labe!!!
- Real Name: Ryan
How's your shift shaft seal look? Was it leaking at all? If not I wouldn't be too concerned about it.
As for the clutch acting wonky, it's the grooves in the basket. Even little small grooves like that can make it feel like your clutch is going out. On the plus side your splines still look really good, so no need to crack the cases. I still say you need to head down here and we'll do a full rebuild for you.
- Skier
Shifter shaft seal was working fine, but if I'm gonna order a bunch of parts might as well make it so I don't gotta get in the clutch for a long time, right?
mgdavis: The 599 is at 34,200 miles now. Lots of fully loaded touring miles and two-up riding.
I wonder if I'm overloading the bike far too much when touring. Scratch that, I know I overload the bike and I'm paying for it now. Oops.
- Skier
60 miles after my KLR-inspired temporary fix, the bike feel way better. should last me until the replacement parts show. Thanks for the suggestion (via AIM), Wrider!
- Skier
My new parts came in today and the still-factory-wrapped clutch basket has those same marks. Wrider was spot-on, they are casting marks and not stress fractures.mgdavis wrote:It looks like your clutch basket has some significant fatigue cracks forming.
- Real Name: Ryan
WHEW *wipes sweat from brow* Glad I was right!
Yeah those stupid casting marks are on everything along those lines. Glad to hear you got the parts in, I want to see pics of the install!
