1981 yamaha xj550 maxim needs help please
When I push the starter button the starter doesn't engauge and the oil level light, on the gauge cluster, illuminates. The oil is fresh and right inbetween the two marks. Any ideas as to why?
- Johnj
- Real Name: Johnny Strabler
The oil is in between the lines because somebody put the correct amount in. And that isn't why the starter doesn't work. Your bike most likely needs to be in neutral and don't pull in the clutch. You could also have a problem with the starter switch or even the starter itself.
Yes that somebody would of been myself.Johnj wrote:The oil is in between the lines because somebody put the correct amount in. And that isn't why the starter doesn't work. Your bike most likely needs to be in neutral and don't pull in the clutch. You could also have a problem with the starter switch or even the starter itself.
The battery was a little low from playing with it yesterday so I hooked it up to a charger and charged it.
This morning i put the battery back in and tried starting it. The first time I pressed the starter button, same thing, just the red "oil level" light came on. Second time the starter engauged and started the bike, so I shut the bike off. Third, fourth, fith, and so on nothing, just that oil level light illuminating.
Does anyone know how the oil level light works ... maybe the sensor, if it has one, is malfunctioning.
Thanks for the help in advance as I would love to get back on the road.
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
The oil light should just be in 'test' mode when the key is on and the bike isn't running yet, to show that the bulb works.
It sounds like you got a bad battery or a bad connection between the battery and the stater, either in the power or ground side. Loosen, check, clean and re-tighten every connection you can find in the starter circuit. If that don't get it, get your battery tested.
No Witnesses....
That is exactly what I have started to do. Does anyone know where the neutral switch is located on my '81 XJ550 Maxim?BuzZz wrote:It sounds like you got a bad connection between the battery and the stater, either in the power or ground side. Loosen, check, clean and re-tighten every connection you can find in the starter circuit. If that don't get it, get your battery tested.
- Johnj
I'd have to bet on the side of the transmission, close to the front sprocket.
Do you have a manual for your bike?
Well after going through the entire starting circuit I finally found the problem. The previous owner had redone the fuse box and never soddered any of the connections, which one came loose.
Thanks for all the help guys. I have learned a lot more about my bike!!!
1981 Yamaha XJ550 Maxim
