In fact, I've ridden it to work three times since I got it back from service. I've recorded two of the rides, but one time the attachment to the bike allowed for too much vibration. Enough that the camera turned itself off after only a short portion of the ride.
The second run with the new camera set up worked great - in terms of vibration, but the camera stopped recording after 39 minutes - reaching the file size limit - and instead of continuing on it stopped.
I'll post a short section of the better quality video, but the camera is pointed at my control cluster. So, there isn't much of a view.
I put on my fork sliders, I put on my frame sliders (Thanks Dean Owens!), camera mount (blah), but for the life of me, I can't figure out how my rear axle sliders are supposed to go on.
Here are the rear sliders I purchased
The instructions are as follows:
1) Support rear wheel and remove rear wheel spindle.
2) Loosen chain adjusters slightly.
3) Fit Evotech crash protector brackets to corresponding sides of swinging arm. Bracket with 'cut out' locates spindle head. Refit rear wheel spindle.
4) Adjust rear chain in accordance with manufacturer's specification, tighten all fittings and secure wheel spindle.
5) Fit Evotech bobbin heads, aligning as required and tighten bolts securely.
ok, so here are my dufus questions. (and before you ask - there are no pictures - which would have alleviated things considerably).
1) What the hell is the rear wheel spindle? I've heard the term before. But what exactly is it?
2) Where exactly are these rather thick pieces of metal going?
I haven't gotten to my tail tidy yet - and I've got a wire to put both my headlights on at the same time.
Of course I was surprised to see a bike that looked so much like my bike - I thought it was my bike from one of the other threads.
Above - FZ6
Above Kawasaki ZR7s
Anyway, I'm really sick today. Ended up not going to work. Will probably have to go to work tomorrow, but won't ride in due to probably still being sick and it is probably going to rain.
Maybe, I'll get a chance to ride in on Wed, Thurs and Friday - and at some point over those rides I'll get to over 1000 miles of my own on this bike.
