82 Honda CM450 carb overflow
finn747
Real Name: sean
Years Riding: 1
My Motorcycle: honda cm450
#1 Unread post by finn747 »
Hello,
I have an 82 Honda CM450 and it is leaking about 1 drop of gas every second out of the left float bowl overflow. I have taken the bowl off and everything looks good. The floats are clean move fine and are in good shape.
Anyone have any ideas on what the issue can be?
Thanks,
Sean
Re: 82 Honda CM450 carb overflow
#2 Unread post by Johnj »
Hello and welcome to the forum. The left carb's float is set wrong. Or the float needle seat is dirty. It's not shutting down the fuel soon enough. So it's leaking.
finn747
Real Name: sean
Years Riding: 1
#3 Unread post by finn747 »
Thanks, I will try and adjust them tomorrow.
#4 Unread post by Johnj »
I don't think it's off by much. Good luck.
finn747
Real Name: sean
Years Riding: 1
#5 Unread post by finn747 »
So I swapped the floats and float valve from the right to the left, the right side is still fine and the left still leaks. I will try shooting some compressed air up there and hopefully that will do the trick.
#6 Unread post by Johnj »
Up where? and is it a CM 450 A, B, or C?
finn747
Real Name: sean
Years Riding: 1
#7 Unread post by finn747 »
It is a C i think. I am going to try and shoot some air up into the float needle seat then clean it out. I'm hoping it may do something.
#8 Unread post by Johnj »
Do you have a manual for your bike?
finn747
Real Name: sean
Years Riding: 1
#9 Unread post by finn747 »
Yes just looked it up and it is a C model
#10 Unread post by Johnj »
Ok set your float level like it says in the book.
