turn signal problem on kawasaki
dlmsmay
Real Name: don
Years Riding: 38
My Motorcycle: 1982 kawasaki kz 100 csr m
#1 Unread post by dlmsmay »
i bought this bike at a junk yard and have got it running well but the turn signals do not work. when i turn the switch both indicators on the dash light up but not the signals. i bought a new flasher and the indicators on the dash flash all the time like a warning signal on a car. can't see anything wrong with the wiring.
this is on an 1982 kawasaki kz 1000 csr
project k.jpg (58.42 KiB) Viewed 3306 times
pchast
Re: turn signal problem on kawasaki
#2 Unread post by pchast »
If the wiring is realllllly good then the switch is suspect. How difficult is it to remove and clean?
#3 Unread post by Johnj »
Ok, you installed a new flasher, and is it both indicators flashing all the time now, right?
dlmsmay
Real Name: don
Years Riding: 38
#4 Unread post by dlmsmay »
the wiring is good and the switch is good. i looked at the book and it said that if any one light in the system is bad then the whole system will not work properly so i am going to systematically replace the lights until i see if that is the problem. thanks for your help
