1999 R1100GS abs motor
C.J.
Real Name: Christopher Snyder
Years Riding: 20
My Motorcycle: 1999 R1100GS
#1 Unread post by C.J. »
The abs motor under the tank remains on when ignition is off. Had to disconnect battery.
Re: 1999 R1100GS abs motor
#2 Unread post by Johnj »
Hello Christopher, and welcome to the forum. What you need is the service manual for your bike. It will have electrical diagrams that will help you troubleshoot the problem. The problem will most likely be where the switching occurs. Good luck. :welcome:
