electricial help needed
- Real Name: john
- Years Riding: 6
- My Motorcycle: 1995 suzuki vs800
i just relocated my license plate on my vs800.. added a side mount with a cat eye taillight. mow i running 2 taillights my stock 3 wire off the bumper and the cat eye also a 3 wire off the side mount. i just spliced the cateye into existing harness for the stock taillamp. everthing working fine , got both running and brake light on both, however when i turn the rear signal lights on the catye on the side mount flashes just alittle. it still is solid but a few leds still flash ever so slightly...i wonder if i can just let it be, or should i be using a load equalizer somewhere. just wondering if state inspection will pass this
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: electricial help needed
you may need a resistor with the led not sure which ones do and which ones don't sorry I can't be more helpful
there aint nothin like it
