02 gsxr 750 sprocket swap
amarino
Real Name: anthony
My Motorcycle: 02 gsxr 750
#1 Unread post by amarino »
Hey everyone quick question... I recently changed the front and rear sprockets on my 02 gsxr 750. I put on a 520 conversion +2 -1. After doing so the bike rides great, no problems with the instalation, except for my speedometer. The speedometer is running slow but not consistantly about 25 mph under at highway speeds and 7 mph slower in residental areas. Any ideas of ways to calibrate the speedo or any other suggestions? Any help will be great! Thanks in advance - amarino
Re: 02 gsxr 750 sprocket swap
#2 Unread post by Wrider »
Yup, speedo-healer.
Your speedometer operates off of how many times the shaft running the front sprocket rotates per given time period (minute, second, hour, etc). From the factory it's set at a certain ratio because it takes X number of times turning the countershaft sprocket to turn the rear wheel one time. When you change your sprockets, it becomes Y amount of times, so the speedometer is off. The speedohealer plugs in between the two, you put in the stock ratio, your ratio, and it adjusts the signal so that your speedometer is now happy.
amarino
Real Name: anthony
#3 Unread post by amarino »
Thank you that's very helpful
