Rake measurement
- Real Name: Lee
- Years Riding: 20
- My Motorcycle: Gsxr 1000
Rake measurement
Hi , I'm trying to import a bigdog pitbull to Australia but need to know a measurement for Australian design regulations , its the measurement from the middle of the headset to the front wheel axle, the measurement is gained by levelling from centre of the top and bottom bearing in headset straight down then across to axle , please help , regards lee
- Johnj
- Real Name: Johnny Strabler
Re: Rake measurement
Well hello Lee and welcome to the forum. The figures you are looking for are published on BigDog's web site and are Frame Rake, 33 degrees, Tree Rake 0 degrees, and Trail 5.59 inches (142mm). I'm sure the guys at BigDogs will be happy to work with you to import a bike, if they don't have an importer already.
- Real Name: Lee
- Years Riding: 20
Yes I've seen the measurements but need to know that the parallel measurement from those two points is no greater than 550mm and thank you for the welcome, regards lee
- Real Name: Ryan
Like JohnJ said, I'd contact BigDog directly and go from there.
