1983 seca turbo starter
turbo
Real Name: walt
Years Riding: 20
My Motorcycle: 1983 seca turbo xj650lk
#1 Unread post by turbo »
starter does not engage when it does cranks two times and then just spins free help. purchase another used starter from ebay put it on does same thing.
Re: 1983 seca turbo starter
#2 Unread post by Johnj »
Walt, the starter bendix or clutch needs attention.
turbo
Real Name: walt
Years Riding: 20
#3 Unread post by turbo »
would it be hard to check the clutch i have used 2 starters and they are both doing the same thing. one more note clutch worked fine thur the gears. is in neutral when i try and start it. also my starter bendix does engade for 2 spins then starter just spins free.
HYPERR
#4 Unread post by HYPERR »
turbo wrote:would it be hard to check the clutch i have used 2 starters and they are both doing the same thing. one more note clutch worked fine thur the gears. is in neutral when i try and start it. also my starter bendix does engade for 2 spins then starter just spins free.
Sounds like the Starter clutch is bad...
turbo
Real Name: walt
Years Riding: 20
#5 Unread post by turbo »
is the Starter clutch hard to replace or fix what part would you order thanks.
#6 Unread post by Johnj »
I'd say medium hard to hard, I don't have one of those manuals
