Fifth Gear Not Working
SnakeskinJim
Real Name: Jim Loder
My Motorcycle: Suzuki DR200
#1 Unread post by SnakeskinJim »
Hey, I've got a 2003 Suzuki DR200 with almost 20k on the odometer that I use as a daily commuter.
The other day I was driving home from work, when I noticed that the fifth (and final) gear wasn't working. When I shifted to it, it basically acted exactly as if it was in neutral, the bike rolled freely with the clutch out, and the engine just revved when I gave it throttle.
Every other gear is completely normal, it's just the fifth that isnt working.
Does anyone have any experience with what the problem might be?
Thanks
Re: Fifth Gear Not Working
#2 Unread post by Johnj »
Hello Jim and welcome to the forum. Are you sure you didn't "short shift" into a "false neutral". Try clutching and shift up again. If that doesn't work I'm afraid that somebody is going to have to go in the gearbox. Good luck.
