Bike runs fine, then doesn't
thiber
Real Name: Tim
Years Riding: 1
My Motorcycle: 86 yamaha virago
#1 Unread post by thiber »
Hello guys. I just bought an 86 virago and she'll start right up and ride smooth for a short amount of time (5 min or so?) and then start to lose power and wants to die. Any ideas what it could be? Not getting enough gas/too much gas? Sticking float valve?
Ive replaced oil and filter, spark plugs, new gas, and sea foamed.
Re: Bike runs fine, then doesn't
#2 Unread post by Wrider »
Does it run better with the choke on when it's trying to die? I'm betting it's running rich, so the choke will kill it even faster.
#3 Unread post by Johnj »
Check the fuel tank vent.
thiber
Real Name: Tim
Years Riding: 1
#4 Unread post by thiber »
Wrider wrote:Does it run better with the choke on when it's trying to die? I'm betting it's running rich, so the choke will kill it even faster.
Havent tried that!
Johnj wrote:Check the fuel tank vent.
Would that be my air box going from the tank into the carb? If so I just replaced that and should be fine. There may be gas flowing into their when its dying which could cause the problem. Hence the loss of power.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#5 Unread post by BRUMBEAR »
If there is gas in there Float is stuck or rather pin is stuck down on the carb.
this is probably your problem it is attached to the float and turns on and off fuel flow.
The vent John is talking about is in every cap or tank itself and stops vapor lock from occuring. So open your cap and see if it stays running if there is no excess fuel flowing.
there aint nothin like it
GS_in_CO
Real Name: Ron
#6 Unread post by GS_in_CO »
BRUMBEAR wrote:The vent John is talking about is in every cap or tank itself and stops vapor lock from occuring. So open your cap and see if it stays running if there is no excess fuel flowing.
You're thinking of something else.
The vent allows air into the tank to replace fuel as the fuel is used. If the vent is blocked then fuel can't get out of the tank as freely as it should. (Picture how you can hold fluid in a drinking straw by putting your finger over the end before you lift it out of the cup or glass.)
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
thiber
Real Name: Tim
Years Riding: 1
#7 Unread post by thiber »
BRUMBEAR wrote:If there is gas in there Float is stuck or rather pin is stuck down on the carb.
I will try opening the cap and seeing if that works! If my float is indeed stuck should I try tapping on the carbs? Ive read that worked sometimes.
Any idea where this vent would be on a virago?
GS_in_CO
Real Name: Ron
#8 Unread post by GS_in_CO »
Start looking for it on the cap.
But the easy test is to loosen the cap and see if the bike runs differently. In some cases you can hear air rushing into the tank as the cap is loosened but not necessarily.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
thiber
Real Name: Tim
Years Riding: 1
#9 Unread post by thiber »
Ran it with cap off, no change in riding. Still sounding crappy and little power.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#10 Unread post by BRUMBEAR »
Carb is the problem,
GS, not thinking the wrong thing just typing it :oops: I should have typed air lock not vapor thanks but the end effect is no air in equals no fuel out and it's moot now :mrgreen: If there is fuel in the airbox and the bike runs poorly you need to pull the carb or carbs and clean the varnish off the jets and seats andclean thefloats and "bullet" valve.
Note: check your tank for rust it may indeed be a problem and will give you fits if not corrected.
