Need help with my (2001 kawasaki eliminator bn125a)
- Real Name: Daniel
- Years Riding: 3
- My Motorcycle: 2001 kawasaki eliminator bn125a
2001 kawasaki eliminator bn125a i dont get nothing when try start it just get click from solenoid replaced it got nothing but same thing changed battery with new one got same thing could it be my electric regulator and i tested starter after taking it off with 12v battery it turns over hard and loud idk what it can been bike is all the way apart checked all the wires they are good idk what to do im tired buying unneeded parts help plzz i payed 700 for bike and im passing it up on parts lol that i dont need by time im done with it it be brand new it got low miles and all plz somebody help it cut off while on way home one day then just clicks now
- Legendary 300
- Real Name: Ron
Re: Need help with my (2001 kawasaki eliminator bn125a)
My best guess is that your battery is not being charged. A few simple tests with a voltmeter would give good information to prove or disprove my guess.
You need to have someone SHOW YOU how to use a voltmeter to do those simple tests.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
Thats is true i put my new battery on and it dies fast do you know what help charge it bc this bike dont have a alternator
It has a electric regulator
- Legendary 300
- Real Name: Ron
A regulator is a device that controls charging. If you have a regulator, you have something that's designed to charge the battery (there are exceptions but they are highly unlikely in your case). Motorcycles don't have 'alternators' like cars do - meaning - a separate rotating piece of machinery usually belt driven. The motorcycle alternator components are usually under covers on the engine at the side.Danielboone wrote:Thats is true i put my new battery on and it dies fast do you know what help charge it bc this bike dont have a alternator
You need a voltmeter and a service manual for the bike. Or someone who has them.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
Okay thanks ima look it to this
- Real Name: Daniel
- Years Riding: 3
So again i order something i didnt need bc i ordered the regulator. A buddy of mine come over and check the voltage reading on my bike
- Legendary 300
- Real Name: Ron
You still need a service manual.
I hope your buddy understands that motorcycles don't usually start charging the battery until the engine RPMs are up quite a ways. That's different from how cars usually are. Service manual should tell you what voltage you'll see at what RPM.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
I also got told it could be the clutch safety switch, kickstand safety switch how true is that jw waiting om body get here
- Legendary 300
- Real Name: Ron
No. That's almost as bad as suggesting that your tire pressure is too low.Danielboone wrote:I also got told it could be the clutch safety switch, kickstand safety switch how true is that jw waiting om body get here
That your starter CLICKS says those switches are just fine.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
How do we do that if the bike wont ever start
- Real Name: Daniel
- Years Riding: 3
Okay thanks and i have the manual that came with the bike and it the starter solenoid that clicks its not on the starter it nexts to the battery
- Real Name: Daniel
- Years Riding: 3
I have the service manual that came with the bike and it's the starter relay/ solenoid that's next to the battery that clicks starter dont make a sound i took it off bike and jump it with jumping cables and it turns over
- Legendary 300
- Real Name: Ron
(second try at response)
Car starters usually have the relay ON the starter. Bikes do NOT.
That your relay clicks says that the safety switches are working right. If they weren't the relay wouldn't shift.
Jumpering power to the starter and the starter rolls says - your starter is fine.
Clicking relay can be- dead battery (because it's not getting charged when you run it or it's a dud and won't hold a charge) OR the relay won't pass current due to old age/ high mileage OR corroded terminals on the wires from the battery to the starter or starter to ground (if any ground cables).
Your first post said that the bike quit while running. Which suggests to me that the battery had finally discharged enough that it couldn't support the ignition system. Which points to not charging. Voltmeter test should tell.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
- Real Name: Daniel
- Years Riding: 3
Bike has 47,000 miles on it and it got new solenoid and I cleaned all the grounds and cable wires all I got left to do is test the voltage
- Legendary 300
- Real Name: Ron
That's a LOT of miles for a small bike! All those steps should eliminate the other possibilities.Danielboone wrote:Bike has 47,000 miles on it and it got new solenoid and I cleaned all the grounds and cable wires all I got left to do is test the voltage
Another thing to be wary of is you probably need to recharge your new battery to start the bike to do the voltage test. I expect it's a pretty small battery which means that you can't use a typical car battery charger because it will put too much current in too quickly and overheat the battery (possibly warping the lead plates in it). Maybe 1 amp at most. Better 1/2 amp charge rate.
If you jumpstart the bike best to get the cables off quickly for the same reason as too big a charger.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Daniel
- Years Riding: 3
But it wont ever turn over so can start it and i bought a expensive battery charger for motorcycles
- Real Name: Daniel
- Years Riding: 3
All it does is same thing after charging battery or trying jump it just click could it realy be starter motor not strong anuff
- Real Name: Daniel
- Years Riding: 3
Can't voltage test until I get it to crank and right now all it does is click after shutting down on me on interstate
- Real Name: Daniel
- Years Riding: 3
Can't voltage test until I get it to crank and right now all it does is click after shutting down on me on interstate not trying to aggravate you just i cant even get it started even when i jump start it or anything but click sucks
