transmission V-Star 1100 07
jviquez
Real Name: James Viquez
Years Riding: 18
My Motorcycle: 2007 V-Star 1100 Custom
#1 Unread post by jviquez »
This past Friday I was riding my Star as I started accelerating I noticed the bike start slowing engine revving high I let go of the throttle realized I lost my gears . The bike is an 07 less then 20,000 miles Upgrades new 2.5 " road burner exhaust Barnett clutch pack Baron oil relocation kit and ram air intake oh also re-jetted the carbs. Bike was running like a dream. Now she sits in the garage with no gears. I shift the shifter nothing. Any ideas ?
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: transmission V-Star 1100 07
#2 Unread post by BRUMBEAR »
Clutch issues for sure is it a hydraulic clutch or cable? If it's hyd. try bleeding and refilling the clutch. If it's cable try to adjust if possible.
there aint nothin like it
jviquez
Years Riding: 18
#3 Unread post by jviquez »
Clutch engages and disengaged the shifter lever is not clicking when I go through the gears. When I engage the gears the bike rolls without any resistance nothing from 1st through 5th.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#4 Unread post by BRUMBEAR »
The description your giving is clutch failure if there was no grinding noise or breaking and your final drive is ok I would start at the clutch you have to anyway. I did a little home work and found the stars to have some kind of $17 upgrade to the clurch just search on YT and you will see the clutch is the gateway to your trans anyway :D
https://www.youtube.com/watch?v=7Ds5bGGCWIo
jviquez
Years Riding: 18
#5 Unread post by jviquez »
Cool Thanks I've started at the clutch you were very correct Sir and I greatly appreciate your help and input.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#6 Unread post by BRUMBEAR »
Anytime I hope you get it sorted if your in Northern NJ I'll even give ya a hand :mrgreen:
xpaceseven
Real Name: peter musk
Years Riding: 2
My Motorcycle: BMW
#7 Unread post by xpaceseven »
Yamaha's fresh-from-the-ground-up V-Star 1100 is a bold new entry in the middleweight market. It stands next to the venerable Virago 1100 in relative size and equipment. Both utilize a 1063cc, air-cooled, single overhead-cam, two-valves-per-cylinder V-twin engine with dual carbs, wide-ratio five-speed transmission and shaft final drive. The similarities end there, however. The new V-Star represents an entirely different perspective. For example, many people think the faithful Virago is ugly -- virtually everyone will agree the new V-Star is not.
rareskyfour
Real Name: rareskyfour
Years Riding: 5
My Motorcycle: bmw 2017
#8 Unread post by rareskyfour »
It is clutch problem also It may not deliver the grunt of Yamaha's 1600cc pushrod V-twin Road Star or approach the Royal Star in visual refinements, but the V-Star 1100 is an extremely well-balanced, middle-of-the-road motorcycle. In our opinion, it's the best package being offered in the 1100 class this year.
