Solvent for cleaning air cleaner on motorcycle
My bike seems to use an oil-foam air cleaner and the cleaning process requires soaking the air cleaner in a high flash-point solvent and then soaking in sae-30 oil according to the service manual. I had a hard time finding any high flash-point solvent so I settled for a can of acetone and also got another can of turpentine both of which I believe are low flash point solvents. Any reason not to use it, do I really strictly need to use a high flash-point solvent or do you all get by with something like acetone or turpentine for cleaning the air cleaner?
"There are a terrible lot of lies going around the world, and the worst of it is half of them are true."
- Sir Winston Churchill
06 Kawasaki Vulcan 500 Ltd.
Thanks for the advice. Since I already bought the acetone I'll probably just use it and make sure its dried out properly. This air cleaner has an element which itself comes out and so no rubber needs to be in contact with the solvent. If I do come across an air filter cleaner at a different auto parts store than the one I went to I'll probably get it.
- Tricycle Squid
- Real Name: Soetjoko Sundhoro
- Years Riding: 5
- My Motorcycle: Yamaha Xeon
Re: Solvent for cleaning air cleaner on motorcycle
Have you ever used reverse osmosis water to clean a motorcycle?
- Tricycle Squid
- My Motorcycle: Ducati
It's a straightforward shower on, wash off recipe that doesn't expect you to utilize some other solvents.
- Tricycle Squid
- Real Name: Cody
- Years Riding: 5
- My Motorcycle: 2011/metal/lower
The purpose of your motorcycle’s intake system is to feed air into the engine.
- Tricycle Squid
- My Motorcycle: Honda
A well-built air filter traps contaminants while allowing air to pass through the intake system.
- Legendary 1000
Harley says to use gas or diesel in their older manuals. They also say to use motor oil.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
