My Mobile has very sound output.
Mike Miller
Real Name: Mike Miller
Years Riding: 11
My Motorcycle: Yamaha R15
Location: 1401 K St NW ,Washington, D.C. United States of America
#1 Unread post by Mike Miller »
My phone is three years old and has very weak audio output. Watching movies or listening to music in public places becomes very frustrating.
I tried exploring various volume booster apps on the App Store, only to find that most require expensive subscriptions, costing up to €11 per week.
Do any of you have suggestions or know of an alternative way to enhance the audio volume on my phone?
Mike :kicking:
Mike Miller
Years Riding: 11
Re: My Mobile has very sound output.
#2 Unread post by Mike Miller »
Updated:
Got this volume booster application for mobile.
Right now it is working perfectly for my problem. I am able to boost the sound of primary and secondary speakers more then the limit.
Got the solution.
Mike :kicking:
FredKim
Real Name: FredKim
Years Riding: 2
My Motorcycle: 1997
#3 Unread post by FredKim »
This app is cool. thanks for sharing.
richardsedmond
Real Name: edmond richards
Years Riding: 5
My Motorcycle: Yahama r6, 2028
#4 Unread post by richardsedmond »
Time to buy a new phone i guess. I need one too, but that is not my priority at the moment.
romulsdefroz
Real Name: lolewif
Years Riding: 1
My Motorcycle: bmw
#5 Unread post by romulsdefroz »
Totally get where you're coming from—had a similar issue with an older phone, and it’s maddening in busy spaces. Those volume booster apps are often overpriced and don’t really deliver. If you're open to it, a decent pair of compact Bluetooth speakers or wired earphones with their own amp can make a big difference.
niloypal
Real Name: niloy pal
My Motorcycle: 2022
#6 Unread post by niloypal »
To repair your speakers, start by determining the type—wired, Bluetooth, or built-in to a sound system—and whether the problem lies with power, connection, or the quality of the sound. Start with the power source: verify that the speakers are connected, the power switch is turned on, and the outlet works. For Bluetooth speakers or batteries, ensure they are charged and well paired with your device.
Secondly, check all cables for any wear, fraying, or disconnection. Attempt to exchange audio cables or test other ports (AUX, USB, HDMI, etc.). Plug your speakers into a different audio source to see if the problem is with the speaker or the initial device.Ensure that your computer, phone, or TV audio settings are correct. Ensure the volume is turned up, the proper output device is chosen, and nothing is muted. For PCs, enter the sound control panel and check speaker output. Install or update audio drivers if need be.For Bluetooth speakers, make sure they're not connected to a different device, and attempt to unpair/re-pair them. If the speaker has a reset button or factory reset, use it.
For distortion or no sound at all, inspect the speaker cones for damage, loose wires within the casing, or overheating. Dust cleaning from ports and grills.For multi-speaker systems or home theaters, check the receiver or amplifier settings and inspect speaker balance and cables.If you’ve tried all troubleshooting steps and the speakers still don’t work, consult the manufacturer’s support or a professional repair service.
rodrigez
Real Name: chris cook
Years Riding: 2
My Motorcycle: Yamaha Yzf-R1
#7 Unread post by rodrigez »
I would just get a new phone or try reaching out to the US Cellular phone number and see if they might be able to help with the noise. Sometimes these issues are hardware-related, but other times it's something they can troubleshoot or fix remotely. I’ve had a decent experience with their support in the past—they walked me through a reset that actually helped. If it’s still under warranty, you might even get a replacement or a good deal on an upgrade. Either way, worth checking before putting more money into a phone that’s acting up
