A bike needs a specific number of volts to start - If you are UNDER that voltage the starter won't spin - 11.8 volts won't do it - usually 12.1 volts won't either.gerpena wrote: i hooked up my meter and when i tried to start i saw the reading across the meter was around 12 volts
bike suddenly not starting... could it be the starter motor?
- TechTMW
- Years Riding: 10
- bikeguy joe
- Legendary 300
Have to agree with nitrus. Check that battery terminals are clean and tight and check your grounds are clean and tight too.nitrus wrote:If the starter motor clicks, you've got power to it.. the problem is most likely on the ground side of the circuit.. Check your grounds.
If your starter motor gear is stuck in mesh you might try putting bike in gear and rock it back and forth that can often free it up and does less damage than hammering it.
if the problem is in fact the battery (and i sure hope it is) shouldnt i be able to jump start the bike with my car?
i tried to and no luck. just the same clicking sound. i took it to an auto parts store and they said the battery took the charge just fine.
should i take out the starter motor and clean it out?
1983 Honda Nighthawk CB550SC
"You start the game with a full pot o' luck and an empty pot o' experience... The object is to fill the pot of experience before you empty the pot of luck."
- mustangski
I replied on your other post before reading this one. I had much the same problem on my old magna, the starter went out on it and I asked around trying to find a new one. Everybody wanted over $300, so I had it rebuilt instead. Cost me $80, if it is your starter take my advice and have it rebuilt.
2001 Victory V92C
2002 Honda Shadow 600 (Finally gettin my wife ridin!)
2000 Harley Davidson Sportster (Sold)
1984 Honda Magna V45 (Sold)
Semper Fidelis
Semper Fidelis
how did you determine it was your starter and not some other electrical problem like the battery? thats kinda where im stuck now. if it is the starter, i dont mind having it rebuilt, i would just like to make sure before i start shelling out 100 bucks.mustangski wrote:I replied on your other post before reading this one. I had much the same problem on my old magna, the starter went out on it and I asked around trying to find a new one. Everybody wanted over $300, so I had it rebuilt instead. Cost me $80, if it is your starter take my advice and have it rebuilt.
- ZooTech
- Years Riding: 18
It's not a matter of it being stuck in the mesh. My van's starter had a weak solenoid which prevented the gear from engaging the flywheel. A simple rap with a tire iron knocked it free so it could extend, engage, and start. It's probably not the cause of his problem, but it's a really simple test and requires no disassembly. Just rap on it and try the starter button.Pongo wrote:If your starter motor gear is stuck in mesh you might try putting bike in gear and rock it back and forth that can often free it up and does less damage than hammering it.
No probs mate.ZooTech wrote:It's not a matter of it being stuck in the mesh. My van's starter had a weak solenoid which prevented the gear from engaging the flywheel. A simple rap with a tire iron knocked it free so it could extend, engage, and start. It's probably not the cause of his problem, but it's a really simple test and requires no disassembly. Just rap on it and try the starter button.Pongo wrote:If your starter motor gear is stuck in mesh you might try putting bike in gear and rock it back and forth that can often free it up and does less damage than hammering it.
I've been known to use "Tool-fine adjustment-hammer" and rap a startermoter too.
- -Holiday
- Legendary 1500
first, check all of your grounds with a meter. Have someone who knows how to use a meter help you, and then pay attention so you get a general idea how to use one.gerpena wrote:how did you determine it was your starter and not some other electrical problem like the battery? thats kinda where im stuck now. if it is the starter, i dont mind having it rebuilt, i would just like to make sure before i start shelling out 100 bucks.mustangski wrote:I replied on your other post before reading this one. I had much the same problem on my old magna, the starter went out on it and I asked around trying to find a new one. Everybody wanted over $300, so I had it rebuilt instead. Cost me $80, if it is your starter take my advice and have it rebuilt.
Then, put the meter on the starter side of the solenoid and try to crank the bike over. Is it getting the proper amount of juice or is it bottoming out down to like 3-4 amps? If its getting the right amount of power to the starter, then look to the starter as the culprit.
if its botoming out you have a bad cell in the battery, or a bad ground.
whatever you do, dont start waisting money replacing "poo poo" until you know it needs to be replaced or rebuilt.
2000 Suzuki Bandit 1200s
Vespa Rally 200 in pieces
I use to have the same problem with my Nighthawk. The clip that goes into the solenoid was pulling just slightly out, enough to break connections. I taped up the solenoid to hold it together well, and sprayed a little WD-40 inside, and never had problems again. This is a recurring problem on older Hondas so check that out. Try just holding the clip into the solenoid with your hand and see if she starts.
Brian
'03 Suzuki SV1000
'03 Suzuki SV1000
