Okay, the skateboard armor isn't gonna do diddly on the road.
Yes, armor is very important... more damage is often done from the impact with the road than sliding. If you've already got a helmet, get gloves and boots next. Watch ebay and craigslist.org for used gear beyond that.
Highsiding is the worse of the two... Lowsiding is still not good.
Check out this thread, elsewhere (the third post): http://forum.motorcycle-usa.com/default ... 1&m=207419
"How to Crash" by Ianisme
Now before some of you regulars start waffling on about not crashing in the first place, this thread is designed to help when fate overtakes desire and you end up tasting tarmac. I plan to start another thread with the opposite title.
There are several ways to crash but your reactions to all of them will be pretty much the same. As I see it the types of crash are
1. The Lowside. This is usually the least painful, both to you and to your bike. The cause is a terminal loss of grip, causing the bike to slide away from under you. The most likely reason is a change of grip in the road surface or simply leaning over too far.
When this happens it is vital for you to RELAX. In fact, relaxation is the single most important part of crashing. Lay back and think of something nice; don't worry about the sparks coming from your bike and try not to think about being hurt. The reason for relaxing is that your body slows much quicker when floppy and you can have time to consider your surroundings.
Try and maintain awareness of your surroundings; where is the bike? If it is in front of you then no problem. If behind then it may hit you. After a lowside the bike is usually in front and poses little or no threat to you. If it is behind then you may have to consider trying to push it away from you.
On no account must you try and stand up before sliding to a halt. Many limbs are broken this way as people misjudge their speed. The only exception to this rule is to avoid imminent danger from oncoming traffic. When you finish sliding, take a moment to do a quick check of yourself. If you judge that nothing is badly damaged then you can think about getting up and surveying the damage.
2. The Highside. This is the one that can hurt. The dynamics of this crash are that the rear tyre slides, then suddenly grips again. The result is that the rider is tossed off the top of the bike with great force (dependant on speed and lean angle). To be honest, you will not have much time to think when this happens.
About the only thing you can do to minimise the damage is to RELAX again. It is probably going to hurt as you have the vertical dimensions of the drop to add to the horizontal components of the speed of the crash. If you are lucky you will land fairly flat and on a nice soft verge. If that happens then the rules for the lowside apply. Pay special attention to where the bike might be as it could conceivably be tumbling through the air right towards you. After years of race marshalling I can state quite categorically that most of the worst accidents are highsides followed by the bike hitting the rider.
There's not a lot you can do to protect yourself from a flying bike. Don't crunch up into a ball or foetal position as this places your spine in an excellent position for being broken. Cover your face with your arms, especially if you are crazy enough to ride with no helmet or one of those stupid beanies. Think about minimising the damage; better a broken arm than a broken neck or fractured skull.
3. The Impact This one is also likely to hurt! This is a very common kind of accident often caused by inattention on the part of other road users. Anybody mention cellphones? The bike usually hits the side of the car resulting in unscheduled flying lessons.
There are a few things you can do to minimise the damage here, but they will require split second thinking on your part. Try and ingrain your possible reactions to any type of crash into your conscious and sub-sonscious minds every time you get on the bike. You will not have time to try and remember this stuff when it happens so try and make it instinctive.
If you are heading for the typical impact with the side of a car, try and stand up on the pegs just before impact. The reason for this is that you should sail over your bars and the car and are then looking at a similar situation to the highside above. The one advantage over the highside is that you will be flying in a fairly predictable arc. You will be going in the direction you were heading at the time of impact and generally not tumbling or twisting. If you get really lucky you might land on your feet, run a few paces then fall flat on your face. That happened to me a long time ago and I escaped totally unhurt.
If you don't stand up before impact then you stand a very good chance of driving your helmet into the side or roof of the vehicle. You also are at serious risk of very bad leg injuries as you hit the bars (fellas should also think what the clocks can do to their "family jewels").
If the vehicle is very tall then standing up and flying over it is not going to work. If the impact is unavoidable then your only option may be to try and initiate a laydown of your bike. This will result in a lowside for which the previous rules apply. If sliding under a truck you will need very sharp awareness to avoid your head ending up underneath the wheels. This does happen. To lay your bike down, stamp hard on the rear brake and lean hard to the side you want to fall. The back wheel should lock and the lean will cause it to slide from under you. As the bike starts to slide then steering hard into the direction of the slide should hasten matters along.
After you have crashed you need to take stock of your situation. If you feel fine then by all means try to move. Check for movement at your extremities before going any further. If in doubt, lay there and don't move. Wait for the medics. They will ask you to remove your own helmet. If you cannot do that then they will do it for you. I hope there are 2 of them because that is really how many you need to do this safely.
I hope this is of some value to you and if anybody wishes to add or dispute these then please feel free to do so. The aim is to come up with a set of ideas worthy of sticky thread status.
Help with Gearing up Please BRAND NEW RIDER!
- swatter555
- Legendary 300
Friend, it was take longer than the period you own the bike to even become mildly competent on it. I know you already bought the bike, but you honestly leaped before you looked.
And you are going without insurance also. If you get into a wreck thats your fault, I think your parents will be liable. If its a serious accident, that could cost you life and limb, then your parents could be sued for tens of thousands.
Im sorry, its hard to ride a bike safely being as cheap as humanly possible. Using gear thats not made for motorcycle accidents is almost useless. Gear thats not made for motorcycling will twist and slide away from the area its supposed to protect.
I hate to be a big downer, but you are not even mildly aware of the true risks of what your undertaking.
Thanks for the reality check, but I'm much more cautious than you might think. I ask about alternative protective gear to learn. I'm financially independent of my parents and they will not bear the price of my mistakes. I am looking into insurance options if it isn't too expensive I will definately get some.swatter555 wrote:Friend, it was take longer than the period you own the bike to even become mildly competent on it. I know you already bought the bike, but you honestly leaped before you looked.
Now the only question I haven't had answered is this.....
When I look on ebay and see gear that is listed for Motocross and Racing...is this type of gear also suitable for street riding??? THANKS!
- swatter555
- Legendary 300
I know that under armor was suggested by a very knowledgable person a little earlier, but there are probably easier ways to tackle this.
www.newenough.com
Just get a textile jacket and gloves. If I am going to be on my bike less than 15 minutes, I will often wear jeans. If Im going to be on my bike any time above 10 or 15 minutes, I will wear textile pants.
If you plan on being on your bike for extended periods, then some sort of textile pants will be required. Also, you will need boots with toe protection(they dont have to be racing boots).
Your just looking for a way to reduce injury, taking sensible precautions(like some textile stuff) should do the trick. If your just zipping over to your friends house, putting on your textile jacket,jeans,gloves,and hiking boots will provide a reasonable minimum of protection.
Buying a mish-mosh of padding to take on and off will be a nightmare. As I said, getting stuff not made specifically for street riding is not very useful. In street riding, the key is abrasion protect. I would think that abrasion protection is not a proirity in motocross, due to its off-road nature.
www.newenough.com
- SheRidesABeemer
If you are going the Ebay route, here is my advice:Surfsage wrote: What material are textile riding gear actually made of?
eBay Motors> Parts & Accessories> Apparel & Merchandise> Motorcycle> Jackets and Leathers>
Do a search for textile, and sort by price. I suggest textile, because it will give you more flexibility when it comes to rain protection. You go leather, you'll need rain gear as well.
I don't recommend you get a one piece; it's just not versatile enough for your limited budget. One piece is terrific when you can buy other jackets for various conditions.
Joe Rocket, First Gear, Alpinestars, Aerostitch are all good reliable brands. You don't want mesh, this time of year. (500, 1000) denier woven Cordura nylon is what you are generally looking for. The higher the number before denier the better tinsel strength. The more armor the better, but your most immediate need is basic protection.
There are plenty of deals to be found this type of year. Quick Ebay tip, check on "completed" auctions. This will show you what people are actually paying for stuff recently. Also, keep an eye on shipping & handling, many people boost this up for profits, it's all part of your cost.
Helmets and gloves can also be found on Ebay. But be very cautious about used helmets. It's probably better to get the best new one you can afford.
Gail
