No spark?
Yamaha650
No spark?
#1 Unread post by Yamaha650 »
I have no spark on my 1985 Yamaha 650 Maxim. Are there particular problems with this normally? Should I get a new Distributor? Any ideas of how to test this also? Thanks!
~Garrett
beerbaron
#2 Unread post by beerbaron »
Is it no spark on all your cylinders ?
Yamaha650
#3 Unread post by Yamaha650 »
Nope, no spark off of anything. :(
9000white
#4 Unread post by 9000white »
it dont have a distributor.
check all the fuses and the kill switch on the handlebar.
dr bob
Mottoxfox
#5 Unread post by Mottoxfox »
Did the bike have spark before or did you buy it this way?
1978 Yamaha XS1100E
1982 Yamaha Seca Turbo
1982 Yamaha 750 Maxim
1983 Yamaha XVZ1200TK Venture
Yamaha650
#6 Unread post by Yamaha650 »
I got the bike this way. the gas tank was rusty, so I got it blasted out, and now I go and try to start it, and there is no spark. I replaced the fuses and fuse box when I got it. The "start" button doesn't work however, it's broken. So unless there are mid-wire fuses somewhere I can't seem to find, i'm confused.
The kill switch is in the "run" position. So the way i'm starting it is by connecting the two posts on the starter soleniod. I know you aren't supposed to do this, but it should still spark, i've had to start my boat many times this way. Any ideas on where a fuse might be that could solve this? I've got brand new spark plugs, and I know there is power going in and out of all the wires on the fuse box because i've tested it.
I'm stumped!
sidecarguy
#7 Unread post by sidecarguy »
maybe some safety mechanism
like in the side stand or clutch
is not letting u start it?
try asking in http://www.xjowners.com
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
