Headlights...
Bman
Headlights...
#1 Unread post by Bman »
My headlight on my '81 Honda CM400 just doesn't light up the road enough anymore. I checked the local dealer for a replacement sealed beam headlight and they wanted $80! for one.
I don't know too much about the conversion kits, but was wondering if there was another alternative than buying another sealed beam?
What seems to be much brighter at night, but still works with side-mounting style headlight?
Thanks for your help!
B
niterider
#2 Unread post by niterider »
You might try JCWhitney or some thing of that sort to find a new light. You might get a holagen light they are very bright. good luck
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
Gadjet
Real Name: Owen Clark
Years Riding: 19
#3 Unread post by Gadjet »
you should be able to find a conversion kit that will replace your sealed beam with a lense and reflector case that holds a standard H3 Halogen bulb. This bulb can then be upgraded to a Sylvania (Osram) Silverstar bulb which will light up the road more than a standard H3 bulb.
*edit*
Bike Bandit has sealed beam headlights for your bike for $42.91 (not knowing which model your bike is, I selected the CM400A from the drop down menu)
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
Bman
#4 Unread post by Bman »
Thank you very much. I will check out bike bandit and the conversion kits! Looking forward to a better illuminated road!
B
