Sportbike Temprature question?
FrankyArseneau
#1 Unread post by FrankyArseneau »
Hi
At what temprature the bike is ready to be ridden. Usualy i start my bike and after one minute of the bike heating up i take off.
But can someone give me an actual temprature i should wait my temp sensor indicates before riding my bike?
Thanks!
SuperRookie
Real Name: Daryl
My Motorcycle: 2004 Ducati 620ie
#2 Unread post by SuperRookie »
I think the engine is warmed up sufficiently when it can idle with no choke...
"Not just your 'ordinary' Rookie..."
VermilionX
Super Legendary 5000
#3 Unread post by VermilionX »
my bike doesn't have a choke. it's fuel injected.
i wait until at least 100ºF.
CNF2002
#4 Unread post by CNF2002 »
I just jump on and go.
2002 Buell Blast 500 /¦\
fireguzzi
Real Name: Trevor
#5 Unread post by fireguzzi »
Bikes are made to be ridden, not to idle.
Just start her up and by the time u get your helmet and gloves on she will be ready to go.
#6 Unread post by Sev »
What I usually do, is put all my gear on, back it out of the garage, and while I'm backing up, I fire it up. So I'm about 1/2 way out of the garage (with the choke on.) I then swing it around in a 1/2 circle so I'm pointing across the driveway, put the kickstand down, hop off, run inside and close the garage door, then run under the closing garage door. Get back tot eh bike, turn off the choke and go.
Sum total, takes about 1.5 minutes estimated.
FrankyArseneau
#7 Unread post by FrankyArseneau »
I see
These are some nice techniques. Thanks all
DivideOverflow
#8 Unread post by DivideOverflow »
Depends on which bike Im riding... on my GV250, if it is cold, just choke for 5 seconds until it idles, do my light checks for my blinkers and brake lights, and take it easy for about 2-5 minutes.
For my KZ650, choke, idle with choke for a couple minutes, turn off choke, the bike most likely dies... re-start bike with choke, and wait patiently. I <3 UJMs. In reality though, it does take about 3-4 minutes to get that bike warmed up.
Dirtytoes
dsadsa
#9 Unread post by Dirtytoes »
on my ex500....i usually leave it on for 5 minutes before i get on it....sometime longer (if it's night and it's cold)...
i've tried just leaving it on and riding, but it just turns off when i'm riding so i don't do that anymore.
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
jmillheiser
Legendary 2500
Legendary 2500
#10 Unread post by jmillheiser »
Mine usually needs to idle on the choke for about 2 minutes, then I let it idle without the choke for another 3 minutes or so, I do this while im turning the bike around in the garage, by the time I have the bike turned around and have my helmet and gloves on the bike is ready to go.
