Chain cleaning.
Ninja Geoff
Real Name: Geoff
Chain cleaning.
#1 Unread post by Ninja Geoff »
Thinking WD-40 followed by a real chain lube. Any thoughts?
After only 2 rides, the chain needs cleaning/oiling. Oh well, it IS a dirtbike that plays in mud.
#2 Unread post by BuzZz »
Clean the crud off with WD and a rag, use a soft bristle brush(piant brush) to scrub out the nooks-n-crannies. Then hit it with a real lube.
Mintbread
#3 Unread post by Mintbread »
I would suggest a proper chain cleaner. They leave no residue as it evaporates quite quickly and does not harm the X-O rings in the chain. Plus it works a million times better than WD.
Ninja Geoff
Real Name: Geoff
#4 Unread post by Ninja Geoff »
Mintbread wrote:I would suggest a proper chain cleaner. They leave no residue as it evaporates quite quickly and does not harm the X-O rings in the chain. Plus it works a million times better than WD.
Chain cleaner to clean a chain? Brilliant! Haha the things that you don't think of at 2 am... And it's non-ring type, just an FYI.
