BuzZz wrote:Scan has it about right. Use the highest gear you can, and cover the clutch so that when it fires, you can pull the clutch and gain control over it. Be careful you don't drop the bike, it's pretty easy to be slightly off balance when it catches and flop over to one side or the other. Hard to look cool when that happens.....
I sense a story...
O.k. by highest gear your can, I wasn't very accurate, I admit. 2nd or 3rd gear shoud do it. When the engine catches, you want to be able to keep up to the bike until you can gain control of the thing.
The higher the gear you use, the faster the wheel will turn the engine over, giving you a better chance of getting it lit.
I've push started my CR500 in 5th(top gear on that bike), I don't have real long arms, but they are a few inches longer now than before I did that.
BuzZz wrote:O.k. by highest gear your can, I wasn't very accurate, I admit. 2nd or 3rd gear shoud do it. When the engine catches, you want to be able to keep up to the bike until you can gain control of the thing.
lol....in 5th!?
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
