82 XJ650 oil filter drip
- Regular
I just changed my oil and afterward I have had a slow drip from the oil filter housing. I took it off and retightened it several times but it still has the slow drip. I replaced both o-rings. Any sugestions ???
- Regular
- TechTMW
- Years Riding: 10
You only need to torque the oil filter housing bolt to 11 lb-ft. That's almost nothing. And it's very sensitive to overtightening so hope you didn't overtighten.
(If you don't have a torque wrench, this is why you need one!)
I had a problem w/ my Seca - the last owner tried to PRY OFF the filter cover with a screwdriver or something - so there was a big gash in the mating surface on the Case... Make sure the mating surface on your bike is clean and smooth
Clean the whole job and then see where the oil is coming from - look for problems in that area.
- Regular
