Full Face Helmet at night question
- FrankyArseneau
- Regular
- moto_hanki
- Skier
Re: Full Face Helmet at night question
In my state it's illegal to ride with a smoked/tinted visor after dusk. Most likely it's illegal in your state, as well. Looks like you've found out why: no matter how good your headlight is, it can be tough to see clearly at night with one.FrankyArseneau wrote:Hi
I have a HJC helmet and i want a tinted shield. But when it comes dark a tinted shield is not very safe. I dont want to remove my tinted shield to put on my stock clear shiel when i want to ride at night.
I have seen some shield insert that you pu on your inside of the shield and you can remove it when you want. Can anyone tell me where i could buy this or let me know a compagny that produce them..if they really exist.
Thanks
As for the removable inserts, I'm not sure where to get those. There are some options for "permanent" ones that attach to your visor, like this one reviewed right on our forums.
That's an entire face shield that does not fulfill the OP's desires. It's just something used to make keeping your visor clear of bugs and whatnot without washing it. You just tear it off and there's a fresh film underneath. They make universal fits that achieve the same thing, without having to purchase a $35 add-on to your $500 helmet.VermilionX wrote:i dont see some for HJC but they have some for my shoei.![]()
http://www.newenough.com/shoei_shield_c ... t_page.htm
what I ended up doing was buying a sheet of static cling limosine window tint from the local auto parts store. I used newspaper to make a pattern that fit on my visor without blocking forward or peripheral vision. Then used my pattern to cut out a slice of the window tint, wet it and applied to the inside of helmet visor. Works very good for day and night riding, and looks quite cool as well. It's been on there for over a thousand miles and I doubt that i'll ever remove it.
Hope this helps
Hope this helps
- TeamONEinc
Smart, real smart not to use a tinted visor at night...a friend of my brother in-law hit the back of a parked truck at night wearing one of those things...the coroner figured it contributed to the accident...sad.
I have a Nolan but the model year before the flip tinted visor was added ..they look good. I like the Nolan...wonder if it can be retro fitted? Use sunglasses right now.
If you're going through hell, keep going.
2005 Moto Guzzi Nevada Classic 750 I.E.
- Bx RedBull
Look into getting a Scorpion helmet. 10-second shield changing system that really is incredibly easy to swap visors. Their anti-fog coating is also another perk that truly is nearly impossible to fog up. I've got both clear and tinted visors and change between the two everytime I ride to work and then leave at night, and it takes less time to do that than to gear up with my jacket and gloves.
Check out their stuff at http://www.ScorpionUSA.com
P.S. No, I am not a rep for Scorpion, just really fell in love with their line of helmets.
