please explain x-siding
Shiv
#11 Unread post by Shiv »
Except you're almost guaranteed tol fly completely off the bike and not recover like that.
Have fun on the open /¦\
www.totalmotorcycle.com
I know, I was surprised too.
< I Fly >
#12 Unread post by < I Fly > »
WTF!
I think this guy is talking about a radiator, not a carborator.
"This member has been banned from the community due to showing a complete lack of basic respect for fellow community members." - Admin
skinnyjoint
#13 Unread post by skinnyjoint »
water in the carb hahah. thats funny. whew.
skoebl
#14 Unread post by skoebl »
JWF505 wrote:the video im posting is a high side, a very extreme high side but a highside none the less. http://www.roadracing.org/media/hshs.html
did you see the way the back wheel lost traction, regained it and launched him off the bike? that is a high side.
That guy has skills. He stuck with it and re-mounted the bike...Crazy...
SV650 K6 <---Suuper Awsome bike
[quote="V4underme"]
If I didn't feel like a monkey &*$%ing a football when I sat on a sporty, I'd probably own one.[/quote]
ZooTech
Years Riding: 18
#15 Unread post by ZooTech »
camthepyro wrote:Water (even a drop) = bad for fuel systems
You don't want any water at all getting into your fuel system at all. So like, if some water gets poored into your gas tank for some reason, you have to empty your gas tank, so the water doesn't get in the fuel system. I can't exactly remember why, but it has something to do with damage to the system.
Water doesn't compress so, if it gets into the cylinder, it will probably bend a push rod or cause other chaos to occur.
camthepyro
#16 Unread post by camthepyro »
Ok, so that's why.
Hey, you're from marysville, OH? I remember hearing that some racer or another was born there. Plus, marysville is the most common town name in the US I believe. I was born in Marysville/Yuba City California (they're basically the same city).
Member of DWPOMD and RATUBBAW
'80 Suzuki GS 450
Skier
#17 Unread post by Skier »
Actually, guys, small amounts of water poured into a carb has good effects for the combustion chamber. Much like Seafoam, it will vaporize and take off a small amount of carbon buildup with it, shooting it out the exahust.
However if you dump a two-liter bottle of water in it all at once, yeah, you're probably going to break something expensive.
ZooTech
Years Riding: 18
#18 Unread post by ZooTech »
Skier wrote:Actually, guys, small amounts of water poured into a carb has good effects for the combustion chamber.
Can we use your bike to define "small amounts"? :lol:
dieziege
#19 Unread post by dieziege »
In all seriousness, water injection is a known, accepted, and well respected practice on performance engines. It is common on WWII era high power airplane engines, super and turbo charged race car engines, and so on. In the past it was even used on some high end "normal" passenger cars. It controls preignition, lowers the intake gas temperature, changes the expansion characterististics of the combustion gasses, and can also help remove certain deposits.
The amount of water injected is fairly small though. Small enough that it all evaporates in the cylinder, so it can't damage the engine. It is usually done like oil injection on the more sophisticated two-stroke engines...there is a tank and a small control valve to "inject" a metered amount of water.
All of that said... I still find the idea of putting water into a car carb as normal maintenance funny as anything... :)
#20 Unread post by Sev »
Low Side - taking a corner to fast and having the bike lose traction and tip of
Hig side - the back wheel catches up with the front wheel and launches the rider in a rather spectacular manner off the front of the bike, then falls over and chases him.
