Hi,
I have a 2000 Suzuki Katana 600 that I didn't ride last year meaning it has set unstarted for close to 2 years. I have been trying to start it.
So far I've replaced the plugs and put in new gas after siphoning the old out. After fiddling with this a while I put a little gas in each of the carbs to get it to turn over. During this process I removed the tank and noticed the lines were completely dry, no gas in the gas filter or anything. I know I had the valve on.
I also noticed the valve having what looks like a vacuum line going into it as well as the fuel line. Does this valve require a vacuum line to operate and could this be siezed up from sitting to long?
Thanks in advance.
Steve H.
