How often do you ride away with your sidestand down? - Page 2 - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
  • Previous
  • 1
  • 2
How often do you ride away not realizing that your sidestand is still down?
Maybe once a week.
1
3%
About once a month, if that.
2
6%
Once a year if ever.
10
31%
Ha, I would never be so squiddy as to ride off with that thing hanging down.
17
53%
What's a sidestand?
2
6%
Total votes: 32
Your vote has been cast.
guitar guru
  • Quote
#11 Post by guitar guru » Fri May 05, 2006 11:43 am
Well, for all of you with older bikes, like me, then you know what I'm talking about. My bike will start with the sidestand down and the clutch disengaged, and will not stop for either reason if you put it in gear.
1988 Kawasaki Ninja ZX600
1986 Suzuki GS550ES
Tarzan
  • Quote
#12 Post by Tarzan » Fri May 05, 2006 12:46 pm
My bike automatically cuts out if you put it in gear with the sidestand down. There was one day it took me ten re-starts, five minutes and a lot of swearing before I worked out why the bike kept stalling when I put it in gear. :oops:
1998 Suzuki GSX750F - all fixed but seriously multi-coloured...
flynrider
  • Quote
#13 Post by flynrider » Fri May 05, 2006 1:47 pm
My current bike won't allow it, but on my older bikes I occasionally rode off with the sidestand down. It was never a big deal because as soon as the sidestand touched the ground, it would flip back into the retracted position.
The more dangerous "oops" was taking off with the forks locked. On my old bikes, the fork lock wasn't built into the ignition switch. It was a separate lock on the side of the fork. I once took off with the forks locked in a left hand turn. I was pulling away from the curb and making a left U-turn, so I didn't realize the forks were locked until I tried to straighten the bars at the end of the U-turn (while giving it some gas). I went flying off the high side and the bike promptly flipped on its side in the middle of the street. Fortunately, no one was watching :laughing: :laughing:
Bikin' John
'93 Honda CB750 Nighthawk
SuperRookie
Real Name: Daryl
My Motorcycle: 2004 Ducati 620ie
  • Quote
#14 Post by SuperRookie » Fri May 05, 2006 3:29 pm
Uhh...like, never...
"Not just your 'ordinary' Rookie..."
fiveoboy01
  • Quote
#15 Post by fiveoboy01 » Fri May 05, 2006 4:48 pm
Well I've had my bike going on 4 weeks now.
Did it for the first time today after backing out of a parking spot. I had left it in 1st gear(parking spot was sloped slightly rearward), backed out of the spot and started to slip the clutch to get moving forward. Bike dies. DUH, kickstand is down.
My bike will start and run in any gear with the sidestand down but ONLY if the clutch lever is pulled in. Let it out, and the bike will die if it's in anything but neutral.
macktruckturner
  • Quote
#16 Post by macktruckturner » Sat May 06, 2006 8:35 am
I may well have the best story related to this question. About 10 days after I got back from Iraq - I was lined up for the MSF ERC, at 0700hrs. Kelley Hill shuts down all vehicular traffic at 0630hrs. Clearly I had to be off the Hill NLT 0630hrs. This is January, fwiw, so it's pretty nippy out. I realize the bike will be COLD so I head out at 0545 to get it started up and warm before I hit the road.
Gear up, insert key, pull clutch, press starter button - nothing. The FI light is on, and I start to freak the hell out - assuming that my PCIIIUSB install somehow borked itself overnight. What does this mechanic turned infantryman do? Does he think "hey the neutral light isn't on?" Oh no, of course not. I proceed to take my motorcycle apart in the dark. All connections are good WHY WON'T MY MOTORCYCLE START. Needless to say, there were drill sergeants on Sand Hill that were proud of my use of profanity that morning. Then it hit me "the bike is in gear you idiot!" Click the shifter up into N - and the fuel pump primes up.... VROOOM.
In short, I couldn't ride off with my sidestand down if I wanted to - especially not if the bike is in gear.
roscowgo
  • Quote
#17 Post by roscowgo » Sat May 06, 2006 12:50 pm
mine has the auto kill switch, but will occasionally miss being all the way up by about an inch..... clutch, shift into first, die like a camel with a bin laden poster stapled to its backside.
niterider
  • Quote
#18 Post by niterider » Sat May 06, 2006 6:28 pm
My bike is smarter than I and will not allow me to ride off with stand down.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
  • Print view
  • Previous
  • 1
  • 2
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
