Using Synthetic
Do you run your bike strictly on synthetic oil?
Poll ended at Fri May 05, 2006 3:52 pm
Yes
14
58%
No
10
42%
Total votes: 24
t_bonee
#21 Unread post by t_bonee »
ZooTech wrote:
t_bonee wrote:Anywho, I've checked for the Mobil 1 10w40 synthetic and can't find it anywhere. Several other weights in synthetic but not the 10w40. Strange.
Dealership? All the ones around here carry it.
Well, I didn't check there :) I looked at autozone, napa, walmart, and a mobil station itself. I will check the dealership now. Thanks!
A dog had his chain reduced one link at a time, every few days, until his chain was so short he could barely move. He never resisted because he was conditioned to the loss of his freedom slowly, over time. Are we in this country becoming like the dog?
CNF2002
#22 Unread post by CNF2002 »
Mobil makes special motorcycle oil in the synthetic flavor.
2002 Buell Blast 500 /¦\
thebighop
My Motorcycle: 1999 Royal Star Venture w/113,000miles
#23 Unread post by thebighop »
I had a minor leak pop up after going to AMSOIL. It is the best for my money ,but it may seep a bit until you get it ran in good, because it thins when it heats up.
"It ain't easy being me!"
MotoF150
#24 Unread post by MotoF150 »
Go to www.amsoil.com and read the test results, every test is explained, pay attention to the 4 ball wear test and read about the zinc content in motorcycle oils. Once I thought the same thing that Amsoil was nothing special untill a friend turned me on and convinced me to try it, the first bike I used Amsoil was a 98 Honda CRB600F3, gone was the engine valve and clucth noise and I could gear shift it as smooth as butter, it ran cooler and it gave me a 15mph higher top speed, I was addicted!! I owned a DRZ400 that was so hard to shift the shifter wore a hole thru my bolt, Amsoil corrected that. If you switch to Amsoil I PROMICE you will see anywhere between 5 to 20mph HIGHER TOP SPEED, smoother shifting, better clutch feel, cooler running engine, faster starting when cold, and "0" internal engine wear. The Dealers want you to use the oil they sell cause they want you bike to break down, thats why they don't sell Amsoil. Remember a 4 cycle motorcycle oil is both a combustion oil and a transmission and wet clutch oil, it has 3 jobs to do, also use synetheic gear oil in the gears of ur shaft drive, "0" gear wear baby!!
9000white
#25 Unread post by 9000white »
engine has 6000 miles and "0" internal engine wear, whats in your engine?[/quote]
shell rotella 15w40 diesel oil--50,000 miles with no wear on cams or any other part.change interval 5000 miles.1982 v45 honda sabre.
dr bob
MotoF150
#26 Unread post by MotoF150 »
Just purchaced 8 quarts of Amsoil 10W40 synthetic for $7.50 a quart and 2 Suzuki oil filters part# 16510-03G00-X07 for $13.95 each
ZooTech
Years Riding: 18
#27 Unread post by ZooTech »
And I just fried some chicken livers with my shirt off.
Skier
#28 Unread post by Skier »
Beware of synthetic oil! It can do terrible things to you and your beloved Motorcycle. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system. It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action. Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the ground! But that's not all... Synthetic oil will round off your gears and spin your bearings. It will also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again. Synthetic oil coats your sight window with a whitish pro-mulsification additive that is both non-removable and highly corrosive.
Synthetic oil will completely leak onto the ground overnight and your dog will drink it and die. Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut. It will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate your timing chain causing it to jump teeth and break your valves to bits. Synthetic oil chemically weakens valves and causes the clearances to change every six miles. Then it melts the black soles of your riding boots night before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose.
It also causes your swing arm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 66,666. It also dries out your wet clutch and wets your dry clutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure. Synthetic oil hides your 12mm socket and puts superglue on your earplugs. Synthetic oil will scratch your face shield and make your gloves shrink two sizes night before track day. Synthetic oil stole your neutral and sold it to the Chinese for $1.25. Synthetic oil will make you grow a tail. Synthetic oil will write long crazy e-mails to your Internet friends and then sign your name at the bottom!
Seetrout
#29 Unread post by Seetrout »
Skier wrote:
Lots of stuff
Guess that's a NO!
Familiarity breeds contempt.
2004 Honda 599
Skier
#30 Unread post by Skier »
Seetrout wrote:
Skier wrote:
Lots of stuff
Guess that's a NO!
Shh, there's a big container of Mobil 1 in the garage for my next change. ;)
