Knighthawk?JediNut wrote:I know that you can abuse a bike a lot easier than a car, so the value of a motorcycle can vary wildly, but it'd be nice to know that, for example, $4,500 is way out of line for a low mileage 2003 Suzuki Volusia vl800.
Also....would that be a decent starter bike? It's not on Knighthawk's fantastic list of starter bikes...so I am not sure.
Specs on a 2003 Suzuki Volusia vl800:
Displacement: 805.00 ccm (49.12 cubic inches)
Engine type: V2
Stroke: 4
Power: 52.00 HP (38.0 kW)) @ 6000 RPM
Torque: 69.00 Nm (7.0 kgf-m or 50.9 ft.lbs) @ 3500 RPM
Compression: 9.4:1
Bore x stroke: 83.0 x 74.4 mm (3.3 x 2.9 inches)
final drive: Shaft drive (cardan)
Dry weight: 239.0 kg (526.9 pounds)
Seat height: 700 mm (27.6 inches) If adjustable, lowest setting.
I think you meant Dragonhawk?
First of all, my list of beginnger bikes is NOT the Bible. It's just some recommendations. Guidelines. Some ideas to consider. It's not a list of absolutes. But I'm flattered that you would take it to heart as you have.
Secondly, those statistics on the bike you want look pretty good to me. Just remember - 527 pounds is freakin' HEAVY. You may be fine with the power, but be careful with the weight. Don't drop it when you're trying to slowly ease into a parking spot or something.
Other than that, I'd say that bike will serve you well, young Jedi.
