neutral instead of second gear ???...
ofblong
Real Name: Ben
#11 Unread post by ofblong »
interesting concept. I guess ill find out how hard it really is when I get a bike but it just seems normal to slam it into gear rather than ""wimp" foot" it like said above lol.
illzomb
#12 Unread post by illzomb »
what's "pre-loading" a shift ??? by the way when i was riding today it went good, not once did i shift into neutral when i didnt want to. thanks for the tips.
Baltimore Newbie
#13 Unread post by Baltimore Newbie »
pre loading the shifter is just putting light pressure on the shifter with your toes before you actually shift. when you are ready to shift roll off the throttle a little, squeeze the clutch lever until the clutch disengages, and since you already have pressure on the shifter it should just "snickt" into gear.
VermilionX
#14 Unread post by VermilionX »
Baltimore Newbie wrote:pre loading the shifter is just putting light pressure on the shifter with your toes before you actually shift. when you are ready to shift roll off the throttle a little, squeeze the clutch lever until the clutch disengages, and since you already have pressure on the shifter it should just "snickt" into gear.
ah, so what im doing when im doing clutchless shifting is called "pre-loading" the shifter.
nice to know the term for it. :D
kellanv
#15 Unread post by kellanv »
you can clutchless shift without "pre-loading" too if you know your gearbox/engine speed combos...
[color=red]I know I'm a dick...no need to point that out.[/color]
[img]http://www.kellanvincent.com/sig.jpg[/img]
[color=red]Thanks and Gig 'Em[/color]
Chris8187
#16 Unread post by Chris8187 »
Noooooo...... it's called clutchless shifting :frusty: . When you pre-load, you aren't shifting gears.
VermilionX
#17 Unread post by VermilionX »
Chris8187 wrote:Noooooo...... it's called clutchless shifting :frusty: . When you pre-load, you aren't shifting gears.
i know, im just saying im pre-loading before i clutchless shift.
:wink:
illzomb
#18 Unread post by illzomb »
this is confusing. so r u saying pre loading the clutch is clutchless shifting ??
Inquizator
#19 Unread post by Inquizator »
illzomb wrote:this is confusing. so r u saying pre loading the clutch is clutchless shifting ??
I'm not 100% sure, but if I'm reading the thread properly, then this is your answer:
VermilionX
#20 Unread post by VermilionX »
nope.
pre-loading is just applying pressure to the shifter before you shift, if you choose to do it before shifting, it's not required.
