d2mini wrote:Ride like they aren't even there. Slow down if you can, but just ride on through. When you are safely in front speed up.
I have to deal with dogs on my bicycle too. They just want to have some fun with you, usually they are not trying to attack and harm you. They are not going to lunge at your bike with the intent of coming in contact with it. They think that if they come at you, they'll get a reaction like you stopping or turning around and going the other way similiar to how another animal would react. So just ride on through. They'll come damn close and may even get in front of the bike for a moment. But they'll move. The last thing you want to do is assume which way they are going to move and you move the opposite way the last second. That will be like trying to pass that person in the hallway and you end up doing that little dance back and forth. Except this time it will be at high speed and you won't get a chuckle out of it.
Man, lots of bad advice. I've been bitten twice by dogs when riding. I've also hit a few when the went after the front tire.
Forget tracking down the dog's owner. You pull up in the drive, what's the dog going to do?
If you are riding in an area with leash laws, there is quite a bit you can do. Call animal control.
Next time you see the dog, call the police and ask to file charges against the owner for reckless endangerment, which is what it's called around here if you place a booby trap. Chasing dogs are a threat to your safety.
If it comes down to either you or the dog, there are other options:
If you have a light, quick dirtbike, use the dog for a jump. Yup, turn around and run it down.
Ammonia in a squirtgun will do the trick, too. This works best at very low speeds, like in a parking lot. Make sure the dog is off to the side, so you don't ride through the squirt. Aim well in front of the dog so the ammonia hits the ground, not the dog, leaving a very strong scent the dog will run in to. Most dogs will immediately break off the chase. After a couple of uses, the dog usually won't chase you any more.
If the dog continues to chase every time you ride by, aim for the eyes. Better a blind dog than a roadrashed (or worse) you.
Three feet of closet rod.
Ride by at night and spill some antifreeze.
