Sprocket Change - Fifth Gear Hack?
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#11 Unread post by Gummiente »
allawybiker wrote:Maybe this is a stupid question to the informed, but can such modifications be made to Shaft drive bikes?
Not without throwing a lot of money at the bike - you'll most likely need someone to cast and machine a new set for you. Final drive gears for shaft driven bikes generally only come in one ratio, as installed from the manufacturer. If enough people complain about it, sometimes an aftermarket company will cast and machine a set with different ratios but that's rare. It's way more common to see this done for cars. If someone wants to change ratios on a shaftie, probably the only route is to change the gears inside the transmission - IF there's an aftermarket company out there already making them.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Telesque
#12 Unread post by Telesque »
It's been my experience that you if you want to change the gears on your car, you either change the rear axle (more common) or transmission (usually if yours is about to puke anyways). But that's probably because I come from a do-it-yourself highschool-metalshop-quality kinda of place. :laughing:
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
bigswifty
#13 Unread post by bigswifty »
that my subset as well.
in fact, i work in a place where i could probly make a gearset for a shaftdrive in about a day
bigswifty
#14 Unread post by bigswifty »
telesque said:
55 is good. 90 is better.
i was talking mph=less mpg
PS i'm editing so much bcozz i'm p_i_s_s drunk.
damn rain....
Gummiente
Years Riding: 38
#15 Unread post by Gummiente »
Telesque wrote:It's been my experience that you if you want to change the gears on your car, you either change the rear axle (more common) or transmission
I should have been more clear on that, I meant that it's easier on cars to change the rear end gearing because there's usually several ratios available. That's a throwback to my stock car racing days, we used to change ratios in the differential depending upon which track we ran at.
It's THAT you ride
Gummiente
Years Riding: 38
#16 Unread post by Gummiente »
f8aw8su wrote:in fact, i work in a place where i could probly make a gearset for a shaftdrive in about a day
Are you a Machinist? I'm a Millwright with a fair bit of experience on lathes and milling machines, but making a set of bevelled gears is WAY beyond my capabilities. :oops:
It's THAT you ride
bigswifty
#17 Unread post by bigswifty »
Are you a Machinist? I'm a Millwright with a fair bit of experience on lathes and milling machines, but making a set of bevelled gears is WAY beyond my capabilities. Embarassed
it's actually really easy. Access to equipment is clutch.
I work in a gear shop. I can't grind a bevel gear, but could cut the gear and send it out for hardening and grinding, then grind the OD journals and whatnot myself.
bigswifty
#18 Unread post by bigswifty »
but one could probly get away without grinding gear faces. It would really be simple.
