Do you think riding at night or day is safer?
- Grey Thumper
- Legendary 1000
- Real Name: Dino
- Years Riding: 9
- ofblong
- Legendary 2500
- Real Name: Ben
uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
96' Honda Shadow Deluxe VLX
- Grey Thumper
- Legendary 1000
- Real Name: Dino
- Years Riding: 9
Not a bad suggestion, I'll doublecheck. Although the problem seems inherent to bike design. Correct me if I'm getting this wrong (or if it doesn't happen to all bikes; I'm pretty new at this) . . .ofblong wrote:uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
Going straight ahead, your lights point in the same direction as the bike and slightly downward, just like a car. However, when a car turns a corner, its lights still point in the same direction as the car, and possibly even slightly in the direction of the curve (if the car rolls outward).
On a bike, the opposite happens. On a right curve for instance, you countersteer left to lean right, into the curve. This makes the headlight point slightly left, and the downward direction of the beam, combined with the bikes rightward lean, makes the beam point even more leftward, exactly where you don't want it to go.
The problem isn't as bad when my lights are on high beam (since the beam points less downward than on low beam), but it's still there, frustratingly.
- Skier
Take a 90 degree corner at 25 MPH. Your headlight's focal point is always lagging behind the important piece of tarmac you are heading to.ofblong wrote:uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
- ofblong
- Legendary 2500
- Real Name: Ben
he said a curve not a corner. Big difference. even my mini van has that problem on a 90 degree corner.Skier wrote:Take a 90 degree corner at 25 MPH. Your headlight's focal point is always lagging behind the important piece of tarmac you are heading to.ofblong wrote:uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
- Skier
Actually there is no difference between a curve and a corner.ofblong wrote:he said a curve not a corner. Big difference. even my mini van has that problem on a 90 degree corner.Skier wrote:Take a 90 degree corner at 25 MPH. Your headlight's focal point is always lagging behind the important piece of tarmac you are heading to.ofblong wrote:uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
- ofblong
- Legendary 2500
- Real Name: Ben
dunno what world you live in but a 35 degree curve is nothing like a right/left hand turn onto another road by use of a 90 degree turn.Skier wrote:Actually there is no difference between a curve and a corner.ofblong wrote:he said a curve not a corner. Big difference. even my mini van has that problem on a 90 degree corner.Skier wrote:Take a 90 degree corner at 25 MPH. Your headlight's focal point is always lagging behind the important piece of tarmac you are heading to.ofblong wrote:uhh mine dont. maybe you need to get them properly adjusted???Grey Thumper wrote:When leaning into a curve, the beam of your headlight points away from the curve, which can be pretty freaky if the road is poorly lit.
