sprocket problems?
flynrider
#11 Unread post by flynrider »
yoman793 wrote:thanks ya'll. i think im going to spring for a center stand. i found one on ebay for around a 100. hey flynrider, the install aint to bad is it? i mean i wont have to jack the bike up to put the center stand on will i? also, does this get in the way of the side stand? thanks for the help guys.
The install is pretty easy. Just a couple of bolts and a spring. You might need to apply a bit of elbow grease to get the spring on there, but it's doable. Mine took about 1/2 hr. to install, with 25 min. spent goofing with the spring.
The centerstand doesn't interfere at all with the sidestand.
As for the shocks, I've been quite happy with the stock ones. I ride two up a lot and just set the preload for maximum stiffness. Works fine for me.
Bikin' John
'93 Honda CB750 Nighthawk
