As for parking your bike in gear or neutral. Personally, I always will park my bike when in public in gear. When parked for the night in the garage, I will put the bike in neutral. That is my routine. You will devise a routine for yourself.viper15 wrote:In my MSF class, I was taught FINE-CC (Fuel Supply Valve, Ignition, NEUTRAL, Engine Cut-Off, Choke/Clutch). My question lies within the Neutral part. Apparently, I should set the bike to neutral prior to killing the engine instead of setting in first gear. So when I start up my bike, I am in the neutral gear. Why is this? Is there anything wrong with leaving in the first gear while parked? If it is required that I set the bike in neutral during parking, then wouldn't that set incentive for someone to roll off with my bike?
Thank you.
As for someone rolling off with your bike. You should consider some sort of theft deterent device. However, if the theif is determined, not many devices will stop them from taking it. With a helper or two and a pick-up or van not too hard to make off with a bike.
Good luck!
