Because the tubes expand when inflated, and installing an old tube in a new tire will result in folds weakening the tube.olebiker wrote:Why?jonnythan wrote:
Always use a new tube.
"When fitting a new tire on a tube-type rim, a new tube should be fitted at the same time. Old tubes can become stretched and, if an old tube is fitted inside a new tire, it can crease or fold over itself and fail due to chaffing and thinning of the rubber."
http://www.dunlopmotorcycle.com/infocen ... ?id=11#faq
"A new tube should be used when installing a new tire. Tubes grow in service, taking a permanent set of about 25% larger than the original size. This makes a used tube too large to use in a new tire, which could cause a wrinkle and lead to tube failure"
http://www.desser.com/actubeinfo.html
"Always use a new tube for a new tyre."
http://www.bridgestone.co.in/tyre/tyrecare/tyrecare.asp
"When fitting new TT (tubetype) tyres, new tubes have to be used. Tubes become stretched in service. If a used tube is fitted in a new tyre, it can crease and fail due to thinning of the tube rubber."
http://www.metzelermoto.com/web/product ... ult.page#4
