Johnj wrote:Open the tank, like leave the gascap off. How does it run ?
Just tried that. Same thing. It actually stalled with the throttle open this time.
I'm really hoping that this is just the carb, and a thorough cleaning will solve it once and for all .
[i]Matthew 6:33 - But seek first His kingdom and His righteousness, and all these things will be given to you as well.[/i]
'93 Yamaha Seca II
'92 Yamaha Seca II (Fixing up)
I'd recommend putting an inline filter between the tank and the carbs this time around. One of the big problems I see with bikes that sat around for a few years is that there is gunk throughout the fuel system. You clean the carbs and it runs better, then they get re-contaminated. It doesn't take much to clog a jet or an idle passage. Fuel filters are relatively cheap and will protect your newly cleaned carbs from anything that may still be floating around in the system.
