That's good, because I'm not exactly sure what one is. Maybe that should be a topic of a thread.Johnj wrote:Being a real "biker" is way over rated.
RhadamYgg
It could be newness, or not being warmed up all the way (more oil in a 1300cc four than a 250cc twin!), but I'll bet it's just the "Suzuki thing." My V-strom has almost 20K miles and still has transmission snits.... eventually you get used to it (or p.o'd) and just stomp on the shifter. V-strom's like a 1950 Ford tractor, ya can't really hurt it anyhow....RhadamYgg wrote:Before the light changes - I try to put it into first gear. No luck…….Anyway, it may be that it needs to be broken in a bit more before it'll cooperate with things like that.
Wrider wrote:Hey, I've had the same thing happen where the bike doesn't want to go into gear. Seems to be a Suzuki thing for some reason.
I'll have to try that out. Rolling forward didn't seem to do much.Wrider wrote:Hey, I've had the same thing happen where the bike doesn't want to go into gear. Seems to be a Suzuki thing for some reason.
Anyway, how I fixed it is letting the clutch engage in neutral for a split second and it will roll the tranny gears far enough that it will engage.
As far as rocking the B-King around for 70 miles... w00t!!!! Congrats!
Hehe, never heard someone refer to their bike being like a tractor, but I actually feel that way about the B-King sometimes.jstark47 wrote:It could be newness, or not being warmed up all the way (more oil in a 1300cc four than a 250cc twin!), but I'll bet it's just the "Suzuki thing." My V-strom has almost 20K miles and still has transmission snits.... eventually you get used to it (or p.o'd) and just stomp on the shifter. V-strom's like a 1950 Ford tractor, ya can't really hurt it anyhow....RhadamYgg wrote:Before the light changes - I try to put it into first gear. No luck…….Anyway, it may be that it needs to be broken in a bit more before it'll cooperate with things like that.
Well, even if you are in NJ as well, it may vary by inspection station.Dragon on Wheels wrote:RhadamYgg,
Could you describe what happened at the inspection? Did you register a time first? When you arrived, did you park in the parking lot or ride up to the inspection area? Then what happened next?
I have to get an inspection done soon(in a few months) and I was wondering what was involved in the whole process. Thank you!
I don't think they are going to g ATGATT on you. Just the reflective tape and your head and eye protection.Dragon on Wheels wrote:Thanks! The Rahway DMW is close enough that I might go there. I usually go there for all the things that aren't offered at other DMVs. I didn't realize they checked your clothing too.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
